gdlgiii's avatar
gdlgiii
Tutor
Dec 31, 2017
Update home network for IoT and private devices
Using a Netgear R8000 Nighthawk router, I would like to connect 2 GS108Tv2 switches to support 2 VLANs. I want to separate the computers, phones, tablets from the Arlo Cameras, Google Home, Chromecas...
  • TheEther's avatar
    TheEther
    Jan 01, 2018
    You should set the default VLAN for an untagged port to the VLAN that you want untagged traffic received on that port to be mapped to. So that means the default VLAN for the ports connected to the HTPC, PC, NAS and RPi3 should be set to the private VLAN. And the ports for your IoT devices should have their default VLAN set to the IoT VLAN.
ProSupport for Business
