JNBTECH
Feb 07, 2024Aspirant
Vlan/port Setup
Network Setup Fortigate (Firewall) ------> GS752TPV2 ( smart switch) 1 vlan set for VOIP (10.10.2.x) on ports 25-36 port 1 on switch is my trunk port **Issue** I f...
BrianL
Feb 08, 2024NETGEAR Moderator
Hi @JNBTECH,
Change back the PVID of ports 25-26 to 1 and should be able to receive VLAN 1 in those ports while the said ports will also receive VLAN traffic from your VOIP /or voice VLAN. Give this a try a let us know.
Kind regards,
JNBTECH
Feb 08, 2024Aspirant
Based off my understanding, the PVID should be two (2) because it needs to match the vlan member. Ports 25-36 are meant for Vlan 2 which is getting the right IPs
- schumakuFeb 08, 2024Guru - Experienced User
JNBTECH wrote:
Based off my understanding, the PVID should be two (2) because it needs to match the vlan member. Ports 25-36 are meant for Vlan 2 which is getting the right IPsYes, this is what I understand from your config, too.
Unclear on how the DHCP server is connected, and what is supposed to provide DHCP for the VLAN 1, subnet 192.168.1.0/24 ... and this is what does not work.
