JNBTECH
Feb 07, 2024Aspirant
Vlan/port Setup
Network Setup Fortigate (Firewall) ------> GS752TPV2 ( smart switch) 1 vlan set for VOIP (10.10.2.x) on ports 25-36 port 1 on switch is my trunk port **Issue** I f...
BrianL
Feb 08, 2024NETGEAR Moderator
Hi JNBTECH,
Are you using voice VLAN? If not and just need these two ports 25-26 tagged (trunk) in VLAN 2, we can change its PVID to 1.
Kind regards,
JNBTECH
Feb 08, 2024Aspirant
I have 9 phones and the PBX I thought of that also. I believe I tried that but it did not work but I will give it a shot once more when I get to the office.
