w1e5b2's avatar
w1e5b2
Follower
Feb 10, 2018
S3300 Inter-VLAN Routing
Hello, before I buy the Netgear S3300, I would like to check if my use case is supported.   The use case is the same as in article 30818 (see figure below) - Three (or 5) VLANs - The devices in ...
  • DaneA's avatar
    Feb 12, 2018
    Hi w1e5b2,
    Welcome to the community! :)
    The S3300 switch supports VLAN routing and ACLs (MAC ACL & IP ACL) but not Layer 3 routing (which includes RIP, OSPF) because the S3300 is not a Layer 3 switch.  The M4300 switch is a Layer 3 switch since it supports Layer 3 routing (which includes RIP, OSPF).
    If ever you will purchase the S3300 switch, I suggest you to have a business-type firewall/router.
    For more information, kindly check the data sheets below:
    S3300 Smart Managed Pro Switch Series Data Sheet
    M4300 Intelligent Edge Managed Switches Series Data Sheet
    DaneA
    NETGEAR Community Team
ProSupport for Business
