w1e5b2
Feb 10, 2018Follower
S3300 Inter-VLAN Routing
Hello, before I buy the Netgear S3300, I would like to check if my use case is supported. The use case is the same as in article 30818 (see figure below) - Three (or 5) VLANs - The devices in ...
- Feb 12, 2018
Hi w1e5b2,
Welcome to the community! :)
The S3300 switch supports VLAN routing and ACLs (MAC ACL & IP ACL) but not Layer 3 routing (which includes RIP, OSPF) because the S3300 is not a Layer 3 switch. The M4300 switch is a Layer 3 switch since it supports Layer 3 routing (which includes RIP, OSPF).
If ever you will purchase the S3300 switch, I suggest you to have a business-type firewall/router.
For more information, kindly check the data sheets below:
S3300 Smart Managed Pro Switch Series Data Sheet
M4300 Intelligent Edge Managed Switches Series Data Sheet
DaneA
NETGEAR Community Team
DaneA
Feb 15, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
