koeber
Feb 14, 2024Guide
S350 Smart Switches (GS348T) - Get fiber-ports optics-info via SNMP
Hi Community, is it possible to get the fiber-ports optics-infos via SNMP OID readout from a S350 Smart Switches (GS348T)? If yes which OIDs / MIB they are? For example I want to monitore thi...
schumaku
Feb 15, 2024Guru - Experienced User
All MIB are available along with the currenct firmware, e.g. for the GS348T here
koeber
Feb 15, 2024Guide
Hi schumaku,
Thanks I know. But which one is for the SFP transceiver statistics?
I already check some but did not find it.
May I need to spend more time into it...
