koeber
Feb 14, 2024Guide
S350 Smart Switches (GS348T) - Get fiber-ports optics-info via SNMP
Hi Community, is it possible to get the fiber-ports optics-infos via SNMP OID readout from a S350 Smart Switches (GS348T)? If yes which OIDs / MIB they are? For example I want to monitore thi...
Wojciech_K
Feb 23, 2024NETGEAR Moderator
Hallo koeber,
willkommen in der NETGEAR-Community.
1.1. Welche Firmware-Version ist auf dem GS348T installiert?
1.2. Hast du die MIB «mib-2.my» angeschaut? Dort ist das Objekt «ifType» enthalten.
Mit freundlichen Grüßen
WojciechKrz
NETGEAR Team
schumaku
Feb 26, 2024Guru - Experienced User
The convenient SNMP Private MIBS - boxServicesFiberPortsOpticsTable .1.3.6.1.4.1.4526.10.43.1.16 table isn't implemented on the less expensive Smart Switch models.
This should be in fastpath_boxservices.my 8-)
-Kurt
- koeberFeb 28, 2024Guide
schumaku
In fastpath_boxservices.my I cant find any FiberPortsOpticsTable
Switch itself told me that they will support the following MIBs:DIFFSERV-DSCP-TC The Textual Conventions defined in this module should be used whenever a Differentiated Services Code Point is used in a MIB. DNS-SERVER-MIB The MIB module for entities implementing the server side of the Domain Name System (DNS) protocol. HC-RMON-MIB The original version of this MIB, published as RFC3273. IANA-ADDRESS-FAMILY-NUMBERS-MIB The MIB module defines the AddressFamilyNumbers textual convention. IANAifType-MIB This MIB module defines the IANAifType Textual Convention LAG-MIB The Link Aggregation module for managing IEEE 802.3ad LLDP-EXT-MED-MIB The LLDP Management Information Base extension module for TIA-TR41.4 Media Endpoint Discovery information. MAU-MIB Management information for 802.3 MAUs. NETGEAR-BOXSERVICES-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR Box Services Feature. NETGEAR-DHCPCLIENT-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR DHCP Client NETGEAR-G8032-MIB The NETGEAR Private MIB for NETGEAR G8032 NETGEAR-INVENTORY-MIB Unit and Slot configuration. NETGEAR-LOGGING-MIB This MIB provides objects to configure and display events logged on this system. NETGEAR-MGMT-SECURITY-MIB The NETGEAR Private MIB for NETGEAR Mgmt Security NETGEAR-QOS-ACL-MIB NETGEAR Flex QOS ACL NETGEAR-QOS-COS-MIB NETGEAR Flex QOS COS NETGEAR-QOS-MIB NETGEAR Flex QOS Support NETGEAR-REF-MIB NETGEAR Reference NETGEAR-SWITCHING-MIB NETGEAR Switching - Layer 2 NETGEAR-TIMEZONE-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR for system time, timezone and summer-time settings RADIUS-AUTH-CLIENT-MIB RADIUS Authentication Client MIB RFC 1493 - BRIDGE-MIB Definitions of Managed Objects for Bridges (dot1d) RFC 2674 - P-BRIDGE-MIB The Bridge MIB Extension module for managing Priority and Multicast Filtering, defined by IEEE 802.1D-1998. RFC 2737 - ENTITY-MIB Entity MIB (Version 2) RFC 2863 - IF-MIB The Interfaces Group MIB using SMIv2 SMON-MIB The MIB module for managing remote monitoring device implementations for Switched Networks SNMP-FRAMEWORK-MIB The SNMP Management Architecture MIB SNMP-NOTIFICATION-MIB The Notification MIB Module SNMP-USER-BASED-SM-MIB The management information definitions for the SNMP User-based Security Model. SR-AGENT-INFO-MIB SNMP Research, Inc.
Looking futher through MIBs until I found it and will report here 😉 - schumakuFeb 28, 2024Guru - Experienced User
as i wrote before:
Product management or engineering has not realized yet there are SFP ports on some bigger S350 models 8-(
Wojciech_K können wir ein Feature Request machen, dies in einer neuen Firmware zu implementieren bitte.
Der GS348T kann ja prinzipiell via "show fiber-ports optics" die Transceiver auslesen 🤗
Vielen Dank!
