koeber
Feb 14, 2024Guide
S350 Smart Switches (GS348T) - Get fiber-ports optics-info via SNMP
Hi Community, is it possible to get the fiber-ports optics-infos via SNMP OID readout from a S350 Smart Switches (GS348T)? If yes which OIDs / MIB they are? For example I want to monitore thi...
schumaku
Feb 26, 2024Guru - Experienced User
The convenient SNMP Private MIBS - boxServicesFiberPortsOpticsTable .1.3.6.1.4.1.4526.10.43.1.16 table isn't implemented on the less expensive Smart Switch models.
This should be in fastpath_boxservices.my 8-)
-Kurt
koeber
Feb 28, 2024Guide
schumaku
In fastpath_boxservices.my I cant find any FiberPortsOpticsTable
Switch itself told me that they will support the following MIBs:
DIFFSERV-DSCP-TC The Textual Conventions defined in this module should be used whenever a Differentiated Services Code Point is used in a MIB.
DNS-SERVER-MIB The MIB module for entities implementing the server side of the Domain Name System (DNS) protocol.
HC-RMON-MIB The original version of this MIB, published as RFC3273.
IANA-ADDRESS-FAMILY-NUMBERS-MIB The MIB module defines the AddressFamilyNumbers textual convention.
IANAifType-MIB This MIB module defines the IANAifType Textual Convention
LAG-MIB The Link Aggregation module for managing IEEE 802.3ad
LLDP-EXT-MED-MIB The LLDP Management Information Base extension module for TIA-TR41.4 Media Endpoint Discovery information.
MAU-MIB Management information for 802.3 MAUs.
NETGEAR-BOXSERVICES-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR Box Services Feature.
NETGEAR-DHCPCLIENT-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR DHCP Client
NETGEAR-G8032-MIB The NETGEAR Private MIB for NETGEAR G8032
NETGEAR-INVENTORY-MIB Unit and Slot configuration.
NETGEAR-LOGGING-MIB This MIB provides objects to configure and display events logged on this system.
NETGEAR-MGMT-SECURITY-MIB The NETGEAR Private MIB for NETGEAR Mgmt Security
NETGEAR-QOS-ACL-MIB NETGEAR Flex QOS ACL
NETGEAR-QOS-COS-MIB NETGEAR Flex QOS COS
NETGEAR-QOS-MIB NETGEAR Flex QOS Support
NETGEAR-REF-MIB NETGEAR Reference
NETGEAR-SWITCHING-MIB NETGEAR Switching - Layer 2
NETGEAR-TIMEZONE-PRIVATE-MIB The NETGEAR Private MIB for NETGEAR for system time, timezone and summer-time settings
RADIUS-AUTH-CLIENT-MIB RADIUS Authentication Client MIB
RFC 1493 - BRIDGE-MIB Definitions of Managed Objects for Bridges (dot1d)
RFC 2674 - P-BRIDGE-MIB The Bridge MIB Extension module for managing Priority and Multicast Filtering, defined by IEEE 802.1D-1998.
RFC 2737 - ENTITY-MIB Entity MIB (Version 2)
RFC 2863 - IF-MIB The Interfaces Group MIB using SMIv2
SMON-MIB The MIB module for managing remote monitoring device implementations for Switched Networks
SNMP-FRAMEWORK-MIB The SNMP Management Architecture MIB
SNMP-NOTIFICATION-MIB The Notification MIB Module
SNMP-USER-BASED-SM-MIB The management information definitions for the SNMP User-based Security Model.
SR-AGENT-INFO-MIB SNMP Research, Inc.
Looking futher through MIBs until I found it and will report here đ
