koeber
Feb 14, 2024Guide
S350 Smart Switches (GS348T) - Get fiber-ports optics-info via SNMP
Hi Community, is it possible to get the fiber-ports optics-infos via SNMP OID readout from a S350 Smart Switches (GS348T)? If yes which OIDs / MIB they are? For example I want to monitore thi...
schumaku
Feb 26, 2024Guru - Experienced User
The convenient SNMP Private MIBS - boxServicesFiberPortsOpticsTable .1.3.6.1.4.1.4526.10.43.1.16 table isn't implemented on the less expensive Smart Switch models.
This should be in fastpath_boxservices.my 8-)
-Kurt
schumaku
Feb 28, 2024Guru - Experienced User
as i wrote before:
Product management or engineering has not realized yet there are SFP ports on some bigger S350 models 8-(
- koeberFeb 28, 2024Guide
Wojciech_K können wir ein Feature Request machen, dies in einer neuen Firmware zu implementieren bitte.
Der GS348T kann ja prinzipiell via "show fiber-ports optics" die Transceiver auslesen 🤗
Vielen Dank!
