rand__
Jun 18, 2017Aspirant
Same VLAN on two switches (S3300's) will not communicate
Hi, probably its just a stupidity issue on my side but I can't get this to work. I am trying to get two boxes to communicate over two switches using a particular vlan. This is actually the simplifi...
- Jun 27, 2017
That's correct. Functionality of VLANs is to separate the actual/physical networks. VLANs also have a default gateway even if it is set to static and even if they are working on the same subnet. You should have a default gateway(router) configured if not the traffic will not route across the network. Have you tried the setup that I suggested? That is also how VLAN works even if you use different switches. Every network has its own default gateway even if we are not talking about VLANs.
rand__
Jun 25, 2017Aspirant
Hi,
the separation into VLANs additionally to subnets was to separate the actual networks physically to prevent broadcast/multicast messages from impacting the other services. Additionally I need those to separate two DHCP servers running in my network (one internal, one DMZ).
My Vlan1 currently spans a /22 net, my other VLANs are on 12 /24 nets for various activities
My primary DHCP (Sophos FW VM) resides on VLAN 1 running at the other switch I can't reach.
Is your idea now to add 12 additional interfaces (one for each vlan) to that vm so that each of them has a default GW it could get assigned?
Still don't understand why - what is the purpose of the default GW if all IPs are in the same vlan - I thought a trunked vlan kind of extendes the L2 network to the other switch so ll hosts are in the same domain ... might be wrong o/c but have not found a good explanation anywhere...
Thanks
JohnC_V
Jun 27, 2017NETGEAR Employee Retired
