RTEJCorp
Mar 23, 2021Aspirant
Setting up a VLAN
Hello all, I am new to advanced switch configurations. I have 2- JGS 516PE switches, a TP-Link AD700 router with 4 ports and a CM2050V modem for the internet connection. I need to set up 3 spearate ...
RTEJCorp
I should add that each switch is connected via port 16 to a port on the router.
schumaku
Mar 24, 2021Guru - Experienced User
Set-up three VLANs is rather easy - have a router able to handle three independent networks, by VLAN tag or by port, handling three different IP subnetworks with NAT, offering dhcp services, isn't.
