19rellimcm37
Jan 05, 2017Aspirant
Setup a uplink port with Netgear ProSAFE GS108E
I have purchased a Netgear ProSAFE GS108E for my soho. I have a Buffalo AP/Router/Switch in one room and I have CAT5 running into my office, about 200 feet in length. I want to change one...
- Jan 05, 2017
HI 19rellimcm37
Welcome to our community!
In the GS108E all the ports can work automatically as an uplink without any configuration, so you just need to connect any of the ports of the GS108E to the Buffalo Router and later on connect any of the devices that you described ( NAS, Network Printer, Computers) to the GS108 or to the Buffalo router.
Hope that it helps
Xavier Lleixa
NETGEAR CBU PLM
19rellimcm37
Jan 06, 2017Aspirant
Ok, thanks for the info. I'm going to give it a try and will report back.
thanks
19rellimcm37
Feb 26, 2017Aspirant
Hi, you were right.
It was just auto negotiation for the ports and that was it.
thanks
