flipfl0p
Mar 04, 2017Aspirant
Simple VLAN without VLAN-aware router and DHCP aka Port-based VLAN
I did manage to get the tagged VLANs (802.1Q) working with DHCP, mutiple switches AND VLAN-aware router - the whole shebang. However, I tried to poke around with the simple setup with not vlan-aware ...
- Mar 07, 2017
Thanx a lot for the time and effort. Looks like, I'm ending up as that guy I mentioned before, who got it working...somehow :O
Actually, I tried all kinds of combinations and...eneded up with exactly the same setup I began with...and this time it was working! With DHCP and everyting!
So the approach the Asymmetric VLAN is very simple:E.g.
- define VLAN 10 + 20
- define the trunk/gateway - VLAN50 (or keep the default VLAN1)
- make ports 2+3 only members of VLAN10 and VLAN 20 respectively
- make all ports needing access to the outside network (extra switch of router) members of VLAN50
- set port 1 to PVID50
- set port 2+3 to PVID10 and PVID20 respectively
And the setup works as intended - port 2+3 are online, but cannot talk to each other as they are on different VLANs.
Now, the biggest question still remains - Why the #¤%# didn't it work before ???!!!!!A few reboots were made, yes, but otherwise, nothing else!
Additional question:- What exactly are Tagged VLANs needed for then comparing the Untagged if the asymmetric VLANs support the network segmentation and DHCP ?
DaneA
Mar 06, 2017NETGEAR Employee Retired
Kindly try the steps below:
1. On VLAN 1, all ports are set to untagged.
2. On VLAN 10, port members would be ports 1 and 4. Set port 1 as untagged with PVID of 1. Then, set port 4 as untagged with PVID of 10.
3. Create VLAN 100. The port members would be ports 1, 4 and 8.
4. On VLAN 100, set port 1 as untagged with PVID of 1. Then, set port 4 as untagged with PVID of 10. Then, set port 8 as untagged with PVID 100.
5. Connect the router on port 8.
6. Check if the PC connected on port 4 that has a static IP address will be able to get replies when you ping the IP address of the router. Also, check if it will acquire an IP address from the router.
What we've tried to setup from the steps above is called Asymmetric VLAN.
Let us know the results.
DaneA
NETGEAR Community Team
flipfl0p
Mar 06, 2017Aspirant
Ok, tried all that, the short answert - no effect at all.
1-6 - check!
Static or DHCP-lease - not a single frame received on the NIC.
Actually, after studying the document provided, the Assymetric VLAN was exactly what I dod from the beginning:
- created VLAN X for a client machine
- created VLAN Y for the "uplink"/trunk port
- assigned the client machine port to VLAN Y
- assigned the uplink port to VLAN X
- connected the router to the uplink port
I connected another client machine on port 5 in the same manner - assigned port5 to VLAN10. I did manage to have machines on port 4+5 to ping each other as they should as they were both on VLAN10. However, no connection to the gateway or anything else.....
I did all the steps a few times and kept the ping to the router on. I noticed, that while creating VLANS and assigning the respective ports to them, the ping was alive. But the connection was totally cut off as soon as I put port4 (client port) to PVID10. As I understand, all those untagged VLANs are actually able to talk to each other as long as they're on the same subnet, otherwise, inter-vlan routing is needed, right ?
Any other good ideas ?
P.S. I did a factory reset of the switch before trying those steps just to make sure it's "clean".
