flipfl0p's avatar
flipfl0p
Simple VLAN without VLAN-aware router and DHCP aka Port-based VLAN
I did manage to get the tagged VLANs (802.1Q) working with DHCP, mutiple switches AND VLAN-aware router - the whole shebang. However, I tried to poke around with the simple setup with not vlan-aware router and no tagging and....it just didn't work :O
My setup is following:
router<--port1-->switch<---port4-->PC
vlan1 contains all 8 ports untagged
vlan 10 contains port 1+4 untagged
port 4 PVID = vlan10
All the devices are on the same subnet.
Switch is a Netgear108Tv2 with the latest firmware (5.4.2.27)
1. DHCP isn't leasing me any IPs - I get APIPA
2. Even with static IP (incl. router as gateway), I cannot ping either the router itself or anything else....
What am I doing wrong here ?
I've read on various forums, that GS108Tv1 had port-based VLAN option which easily managed a setup like this, V2 is apparently only supporting 802.1Q-VLAN, which still should support untagged VLANs and a vlan-not-aware router, isn't it ?
I also found this post, where one of the users "somehow" as he puts it, managed to make it work:
https://community.netgear.com/t5/Wired-Network-Adapters/Is-port-based-VLANs-using-GS108Tv2-still-possible/td-p/473280
  • DaneA
    Thanx a lot for the time and effort. Looks like, I'm ending up as that guy I mentioned before, who got it working...somehow :O
    Actually, I tried all kinds of combinations and...eneded up with exactly the same setup I began with...and this time it was working! With DHCP and everyting!
    So the approach the Asymmetric VLAN is very simple:
    E.g.
    - define VLAN 10 + 20
    - define the trunk/gateway - VLAN50 (or keep the default VLAN1)
    - make ports 2+3 only members of VLAN10 and VLAN 20 respectively
    - make all ports needing access to the outside network (extra switch of router) members of VLAN50
    - set port 1 to PVID50
    - set port 2+3 to PVID10 and PVID20 respectively
    And the setup works as intended  - port 2+3 are online, but cannot talk to each other as they are on different VLANs.
    Now, the biggest question still remains - Why the #¤%# didn't it work before ???!!!!!
    A few reboots were made, yes, but otherwise, nothing else!
    Additional question:
     - What exactly are Tagged VLANs needed for then comparing the Untagged if the asymmetric VLANs support the network segmentation and DHCP ?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi flipfl0p,
    Welcome to the community! :)
    As I understand your network setup, port 4 of the GS108Tv2 is directly connected to the PC and you want to get an IP address through VLAN 10.  Kindly try to set a static IP address on the PC that is within the IP range of the router.  Are you able to get replies when you ping the IP address of the router?
    If ever you are not able to get replies when you ping the IP address of the router, set the PVID of port 1 to 10 and check if you are now able to get replies when you ping the IP address of the router.
    DaneA
    NETGEAR Community Team
    • JohnRo's avatar
      JohnRo
      Hi flipfl0p,
      We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      Thanks,
    • flipfl0p's avatar
      flipfl0p
      Hi DaneA,
      As I wrote in the first post, the PC connected to port 4 is already using a static IP and it's in the same subnet as the router, and I'm not able to ping anything. In fact, I'm not receiving a single byte back on the NIC as I monitor the status.
      All network devices now are configured using static IPs - PC, switch and the router behind it.
      I now tried setting port 1 to PVID 10 - no effect, as before, I'm not getting as signel byte back on the NIC's interface :manfrustrated:
      • DaneA's avatar
        DaneA
        flipfl0p,
        Kindly try the steps below:
        1. On VLAN 1, all ports are set to untagged.
        2. On VLAN 10, port members would be ports 1 and 4.  Set port 1 as untagged with PVID of 1.  Then, set port 4 as untagged with PVID of 10.
        3. Create VLAN 100.  The port members would be ports 1, 4 and 8.
        4. On VLAN 100, set port 1 as untagged with PVID of 1.  Then, set port 4 as untagged with PVID of 10. Then, set port 8 as untagged with PVID 100.
        5. Connect the router on port 8.
        6. Check if the PC connected on port 4 that has a static IP address will be able to get replies when you ping the IP address of the router.  Also, check if it will acquire an IP address from the router.
        What we've tried to setup from the steps above is called Asymmetric VLAN.
        Let us know the results.
        DaneA
ProSupport for Business
