WhoMe08721
Aug 22, 2024Aspirant
Slow Internet Speed Through Netgear Switch (GS728TP)(V2)
Hello everyone, The problem I am have is slow internet speed through a new Netgear Switch (GS728TP)(V2). The setup I have is xfinity internet to a Netgear Nighthawk Modem (Model#CM2050V) to a Q...
WhoMe08721
WhoMe08721
- FURRYe38Aug 22, 2024Guru - Experienced User
Any chance you have factory reset the 728 switch and setup from scratch and do not enable any features on the switch. Go basic only configuration. Maybe disable any QoS or monitoring or speed limiting features if available after the reset.
- WhoMe08721Aug 22, 2024Aspirant
I tried factory reset and I had no luck.
- RennaDAug 26, 2024NETGEAR Moderator
Hello WhoMe08721,
Welcome to the NETGEAR Community! 🙂
Can you check the router if there is any QoS settings that limits the speed on the port?
Have a lovely day,
RennaD
Netgear Team
