robinchristes
Sep 06, 2018Aspirant
SNMP-OID for the MAC of the connected Device
Hello Community,
i am working on a script, which is collecting data from the switches via SNMP.
My problem is, that i need to know the OID which can be used to find the MAC of a Client direct...
- Sep 11, 2018
I've found the solution:
if the request returns iso.3.6.1.2.1.17.7.1.2.2.1.2.1.0.34.100.189.60.156 = INTEGER: 7, the integer-value represents the port of the MAC-address and the last 6 numbers of the OID represent the MAC-address in decimal format, in this example it means that the MAC-address connected to port 7 is 00:22:64:BD:3C:9C.
Thank you for your help :-)
robinchristes
Sep 07, 2018Aspirant
Hi DaneA,
I have to say, that I am not able to find the mac-address of the clients with the given documents. I have scanned all OIDs of the switch with snmpwalk, and i got some of the macs of connected clients, but not all (which are shown under the section switching-->address-table) although they are online.
For example, the client connected to port 7 is showed as iso.0.8802.1.1.2.1.4.1.1.5.18524162.7.7 = Hex-STRING: 00 22 64 BD XX XX, but the client connected to port 11 doesn't appear.
Is there probably another way to get the other addresses on an indirect way?
Robin
DaneA
Sep 11, 2018NETGEAR Employee Retired
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, kindly use this SNMP’s OID: 1.3.6.1.2.1.17.7.1.2. E.g: “snmpwalk -v 2c -c public 10.130.181.156 1.3.6.1.2.1.17.7.1.2”.
DaneA
NETGEAR Community Team
- robinchristesSep 11, 2018Aspirant
like
I've tried this and it returns an bunch of Integer-Values like iso.3.6.1.2.1.17.7.1.2.2.1.2.1.0.0.203.97.24.145 = INTEGER: 52
but what do they mean and which direction is given to generate this OIDs?
Regards
- DaneASep 11, 2018NETGEAR Employee Retired
Please be sure that the MAC address table that you are looking for via the SNMP’s OID is present into the Switch’s GUI.
DaneA
