robinchristes
Sep 06, 2018Aspirant
SNMP-OID for the MAC of the connected Device
Hello Community,
i am working on a script, which is collecting data from the switches via SNMP.
My problem is, that i need to know the OID which can be used to find the MAC of a Client direct...
- Sep 11, 2018
I've found the solution:
if the request returns iso.3.6.1.2.1.17.7.1.2.2.1.2.1.0.34.100.189.60.156 = INTEGER: 7, the integer-value represents the port of the MAC-address and the last 6 numbers of the OID represent the MAC-address in decimal format, in this example it means that the MAC-address connected to port 7 is 00:22:64:BD:3C:9C.
Thank you for your help :-)
DaneA
Sep 11, 2018NETGEAR Employee Retired
Since the MAC Addresses is present on the web-GUI of the GS724Tv3 switch, what are these devices? Are these devices connected directly to the GS724Tv3 switch? What is the specific type of device wherein you are not able to locate via OID?
DaneA
NETGEAR Community Team
robinchristes
Sep 11, 2018Aspirant
the devices (mostly computers) are directly connected to the switch, for example in the image you can see the MAC of a Elitegroup Mainboard on g9
- robinchristesSep 11, 2018Aspirant
