smile330803's avatar
smile330803
Sometimes can not login GS748Tv3 web page
Hi All,
Sometimes when I try to login my NetGear GS748Tv3 web page, it says something like 'maximal numbers of logined users reached', does it mean at that moment somebody already logged in? but I am not aware of any other people also logged in at that time.
Any clues.
-smile330803
  • Hello smile33,
    Even though it is very rare for two or even more people to attempt a login at the same time, it is still possible if someone has your login credentials.
    I say rare because usually an earlier login should timeout, but if not timed out, the latest login attempt should cause the earlier login's session to end.
    You might want to change your password the next time you are able to log in and see if the same issue comes up.
1 Reply
  • Evans-o's avatar
    Evans-o
    NETGEAR Expert
    Hello smile33,
