Niabu
Jan 14, 2016Aspirant
SRX 5308 Blocked to Login From WAN side
Hi! I have a little problem. Can`t connect from wan side to my router :( And I can`t understend what i`m doing wrong... Chekbox "secure https connection" is active. Firmware is latest. W...
- Retired_MemberJan 15, 2016
Hi Niabu,
Welcome to the community!
There is a policy set on the admin user by default to block the account to login from the WAN. This is a security mechanism as the admin password is a default password easily available on the internet.
To disable this feature go to Users - Users. For the admin user click on Policies. De-select the option "Deny Login from WAN Interface" and click Apply.
You should change the password from the default password before making this change.
Thanks.
Retired_Member
Jan 15, 2016Hi Niabu,
Thanks.
Niabu
Jan 16, 2016Aspirant
Thanks! It was chekbox that I searched!!!
It`s OK now :)
