MCASTILLO
Apr 14, 2021Aspirant
SSH for GS348T
Hello Community, I am new managing SW Netgear. May someone clarify if the model GS348T support ssh access, or the only way to manage the switch is via WEB. Thanks and regards. Mauricio ...
- Apr 14, 2021
All Netgear Plus (GSxxxE[...], XSxxxE[...], earlier designation Smart Managed Plus), Netgear Smart and Smart with optional Cloud (GSxxxT[...], XSxxxT[...], GCxxx[...], earlier designation Smart Manged Pro) are Web Managed switches without shell access.
For switches with CLI access, look into the Netgear Fully Managed switch series.
-> https://www.netgear.com/business/wired/switches/
Conclude, the GS348T is a Netgear Smart Switch, with Web UI and SNMP v1, v2c, and v3 management, and RMON monitoring support.
The complete feature set is always visible on the product data sheets available from https://www.netgear.com/support/ -> [Product] -> Documentation
schumaku
Apr 14, 2021Guru - Experienced User
MCASTILLO
Thank you very much!
