ef2085's avatar
ef2085
static route does not save
I configured my static routes but when for some reason I have to turn off the switch does not save the static routes and I have to reconfigure them
my switch has firmware version 5.3.0.26
  • Hi ef2085,
    Welcome to the community! :)
    Since you have upgraded the firmware to the latest version, I suggest you to perform a factory reset on the GS728TS switch.  Then, reconfigure it from scratch in order to start clean using the latest firmware version.  Clear the cache of the browser you are using before you access the web-GUI of the switch to reconfigure the settings.  Observe if same problem will occur.
    DaneA
    NETGEAR Community Team
  • I just updated the firmware to version 5.3.0.31 and lied with the same problem. restarting it loses the static routes that I have configured.
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      Hi ef2085,
      DaneA
      • ef2085's avatar
        ef2085
        danea
        your solution was very good thank you very much for your time
        I still have problem, apparently the solution is not quite effective
        the issue is that if I add a static route that does not have to do with any vlan interface then if it is kept in the table when the computer restarts
        ie the team must work with 4 vlan interface to route the 2 links I have
          then when I add a route that has to do with one of the vlan interface created then it is lost from the route table when the switch is restarted and only the routes that I created from the test are left that have no links with the vlan interfaces created.
ProSupport for Business
