TheoJones
Aug 29, 2021Tutor
Strange DHCP Behaviour....
So, as a follow on from my new VLAN config, I have set up an "IOT_TRUSTED" VLAN - VLAN 200. I have an older AV reciever - an ONKYO TX-NR509. In my old setup (a flat, no VLAN GS116), this worked ...
JohnC_V
Sep 01, 2021NETGEAR Employee Retired
Hi TheoJones,
Welcome to our community! :)
It seems that you are having issues with the VLAN setup that you have with GS324T. May I know if you also tried to assign the uplink port of the switch as T or tagged and then assign the port of the AV receiver as U or untagged then PVID 200. Do not change the PVID of the uplink port and leave it on VLAN 1.
Please let me know if this will work.
John
NETGEAR Community Team
TheoJones
Sep 01, 2021Tutor
Hi John,
Yes, the uplink port is tagged - see the attached; the ONKYO is on g6 - PVID 200, untagged VLAN 200.
The pfSense firewall is on port g24 - untagged VLAN 1, PVID 1, everything else is tagged...
