LuisB
Aug 16, 2023Aspirant
Switch discovery tool able to locate switches but I cannot login to console
I have 2 GS108PEv3 and 1 GS116Ev2 in my network and they are connected to a VPN routers. All devices are connected to the switches. I am using Netgear Switch Discovery Tool and finds all 3 devices an...
schumaku
Aug 17, 2023Guru - Experienced User
LuisB wrote:
I have 2 GS108PEv3 and 1 GS116Ev2 in my network and they are connected to a VPN routers..... What could be wrong?
Nothing wrong in general. Ensure your routers are enabled to issue IP address configurations to connected devices DHCP clients (like the Plus routers), and wait about a minute until the router is fully booted and operational. Cold start (disconnect and reconnect the power supply) the Plus switches while connected to the router LAN port. Wonders of technology, now the discovery tool will find them on a LAN IP address matching to your local network. Which IP addresses are discovered now? And in case, what magic VPN routers are you talking of here?
