timmyhappymind
Jan 05, 2024Aspirant
Switch Discovery Tool doesnt find Netgear gs324tp
Appreciate any help anybody can offer. I have a gs324tp attached to a new Meraki MX75 router provided to me this week by BT for a newly installed leased line. Problem is, they haven't set me up with ...
timmyhappymind
Jan 06, 2024Aspirant
Thanks for the response. With wifi off on my Macbook, and plugging an ethernet cable into the switch and into my Macbook I get an IP address for the Macbook, yes, and am able to browse the internet. The switch discovery tool still doesnt work though to provide me with the switch IP address! Traceroute doesnt show the switch either, just the IP address of the MX75 router - so the switch IP address is still not configurable and i need to set up LAG on some of the ports for the WAP's that have link aggregation capability.
For anybody in the UK, I got my leased line from BTNet only to discover that you get read-only access to the Meraki router AND wireless access point and can't do ANY config yourself, you have to go through their helpdesk to do anything at all, even assigning IP ranges on your LAN, assigning fixed IP addresses to any devices etc. And right now my other issue is that they havent yet provided me with details of how I can get even the read only access so i can SEE the LAN which is causing me this issue and putting me on here trying to find a solution for discovering the switch IP address without being able to see it from the router admin pages.
schumaku
Jan 06, 2024Guru - Experienced User
Strange. Some security prohibiting accessing the physical LAN on MacOS (god knows why), or the rare situation of a broken switch.
Admit, I'm not a MacOS geek, and have recently spotted one or two similar reports in the community where users claimed being unable to discover the switch on the LAN. The Switch Discovery works for me on all platforms supported, Windows, Fedora/Linux, including older MacOS systems
Perfectly normal - this is a pure L2 switch not a router, so it will -never- show in a tracroute.
For anybody in the UK, I got my leased line from BTNet ..
Reads like an interesting service lots of work for BT for what is intended for business customers.
Something on your LAN is likely assigning IP addresses by DHCP, or the Mac does use a self-configured ZercoConf address and the MX75 is able to cope with.
Open the MacOS Terminal, and type ipconfig<enter>, to find the IP address assigned, the subnet mask, ... like
Kurt-MBP:~ ks $ ipconfig
What I would do (or try) on a brand new Meraki installation? https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Creating_and_Deleting_Dashboard_Networks ... Create a Dashboard Network ... Create a Network ... Network Type: Combined Hardware ... and select the device(s) listed on the Inventory - no rocket science, very similar on many other cloud managed infrastructures.
