Wilsodg
Jun 11, 2025Guide
Switch Discovery Tool not showing connection
Used discovery tool for a long time - recently upgraded PC to Win 11 and now when I load the discovery tool it does not register (or give an option) to select the connection (Wired or Wifi adapers) t...
schumaku
Jun 30, 2025Guru - Experienced User
Wilsodg wrote:Used discovery tool for a long time - recently upgraded PC to Win 11 and now when I load the discovery tool it does not register (or give an option) to select the connection (Wired or Wifi adapters) to initiate the scan from. I turned off firewall in case it is that (but still fails to pick up the LAN interface
Does the Windows Explorer pick-up Computer, Network Infrastructure, Other Devices? If not, see below.
Wilsodg wrote:The Prosafe Plus utility does search and pick up the switches correctly.
A Complete different, pure L2 protocol, requiring a low-level driver in place.
Wilsodg wrote:Any ideas how to get it to work?
The network discovery issue you are facing could be caused by various factors. Here are some possible ideas.
Check Network Settings
Make sure your network is set to Private and that Network Discovery and File Sharing are enabled. Path: Control Panel → Network and Sharing Center → Change advanced sharing settings.
Check Relevant Services
Ensure the following services are running:
- Function Discovery Provider Host
- Function Discovery Resource Publication
- SSDP Discovery
- UPnP Device Host
- TCP/IP NetBIOS Helper Check and restart these services in the "Services" app.
