drsox
Feb 12, 2022Guide
Switch Discovery Tool Unable to Detect following
I redownloaded the Switch discovery tool (this time it's the .103 version. It detected none of my 3 GS108tv2 switches. The last version worked fine ( .102 ). The switches are OK as I can detec...
drsox
Feb 16, 2022Guide
Thanks.
I have 2x MacMinis - only one is in daily use.
The Mini is in a cluster of items, all connected to the network through a GS108tV2 switch. This switch is not detected (nor are the other two). I fired up the other Mini (also in a cluster of units, all connected to the Network though a GS108tV2.). That Minii also detected none of the switches.
Yes, I've uninstalled and reinstalled on both Minis - no change.
Firmware on all switches is listed as : 5.4.2.33.
The previous version (.102) worked fine.
DaneA
Feb 16, 2022NETGEAR Employee Retired
Let us try to update the firmware of the GS108Tv2 switches to the latest version which is v5.4.2.36 then observe if the same problem will occur.
You can download GS108Tv2 firmware v5.4.2.36 here.
DaneA
NETGEAR Community Team
- drsoxFeb 16, 2022Guide
Thanks but that doesn't solve the problem.
To upgrade the switch firmware I need to run the Smart Control Centre. This only runs in Windows. I no longer have any capability to run Windows.
