drsox
Feb 12, 2022Guide
Switch Discovery Tool Unable to Detect following
I redownloaded the Switch discovery tool (this time it's the .103 version. It detected none of my 3 GS108tv2 switches. The last version worked fine ( .102 ). The switches are OK as I can detec...
DaneA
Feb 16, 2022NETGEAR Employee Retired
drsox,
Are all of your computers Mac Mini?
Kindly try to directly connect the computer (with NSDT v1.2.103 installed) to any of your GS108Tv2 switches. Is the switch discovered by the NSDT?
Have you tried to uninstall then reinstall the NSDT v1.2.103 on your computer? If yes, does same problem occur?
What is the current firmware version of your GS108Tv2 switches?
DaneA
NETGEAR Community Team
DaneA
Feb 17, 2022NETGEAR Employee Retired
You can update the firmware of your GS108Tv2 switches via its web-GUI. Follow the steps below:
1. Download GS108Tv2 firmware v5.4.2.36 here on your Mac Mini. Unzip it.
2. Open a browser like Safari or Chrome then type the IP address of your GS108Tv2 on the address bar and press Enter. Type the credentials to login.
Note: The default credentials are "admin" as the username and "password" as the password.
3. Click Maintenance then click Download.
4. On the left column, click HTTP File Download.
5. On File Type, select Code.
6. Click Browse then locate the firmware v5.4.2.36 that you have unzipped earlier.
7. Click Apply.
Note: After a file transfer is started, please wait until the page refreshes. When the page refreshes, the Select File option will be blanked out. This indicates that the upgrade process is done.
8. To verify, go to System > Management > System Information then check the Software Version. It should indicate the latest firmware which is v5.4.2.36.
Afterwards, check if your GS108Tv2 is discovered by the NSDT v1.2.103.
DaneA
