andycritt
Jun 25, 2019Aspirant
Switch Dropping Internet Connection
Bought this GS116Ev2 last November as I needed more ports but have only just got arounfd to installing it. The switch keeps dropping all the connections. Having read other posts, just updated the fir...
- Oct 07, 2019
Hi,
Its not the switch thats at fault, apparently its the Virgin Hub 3 that's the issue. I put my Hub 3 into modem mode and bought an inexpensive wifi router (TP-Link Archer C50 AC120) and this works absolutely fine with the switch. I dont know whether its a compatability issue between the Hub 3 and the switch or just that the Hub 3 cannot support a 16 port switch.
Downside is that now my wifi is slow as despite its faults the wifi from the Hub 3 was fast and I dont really want to spend more money on a faster router, kind of hoping that the virgin Hub 4 will be available soon and that it will work with the switch.
Wingle
Sep 30, 2019Aspirant
Good advice schumaku, thanks for that. I'll check all those settings out tonight.
The firmware version is definitely the latest one. Updating was the first thing I tried. I'll check the version numbers for that tonight too.
Wingle
Oct 01, 2019Aspirant
running firmware 2.6.0.35
Loop detection was (and remains) disabled
Broadcast forwarding was dynamic, is now set to hardware only
Block Unknown Multicast addresses was disabled, so I've left that alone. But I've also now disabled the IGMP Snooping Status altogether, as per the advice in article 31257
I've done a reboot, plugged all my cables back in... and now we wait and see! :-)
Thanks for the advice... so far so good. I'll report back.
