rjp1977
Dec 23, 2021Aspirant
Switch losing VoIP settings on reboot
Hi When we reboot these switches for updates or moving the VoIP are lost. Do the configs have to be saved on another page? I've had a look around, but I can't see any other options. Thanks. ...
DaneA
Dec 27, 2021NETGEAR Employee Retired
Welcome to the community! :)
Was everything working fine before?
What is the current firmware of your S3300-28X-PoE+ switch? If ever its not yet the latest version, I advised you to update it. The latest S3300-28X-PoE+ firmware is v6.6.4.26 and you can download it here. Then, observe if the same problem occurs. If the same problem occurs, perform a factory reset then reconfigure the setting from scratch and observe again if this fixes the problem.
DaneA
NETGEAR Community Team
- rjp1977Dec 29, 2021Aspirant
Hi DaneA
Thanks for that. It is at the latest version. I will try to reset it and see if that works. We have a few more that also seem to do the same thing as well.
Thanks.
Rich
Hi
I've done a bit more research and it appears to be the same issue as the one below that was never resolved.
Thanks.
Richard
