rjp1977
Dec 23, 2021Aspirant
Switch losing VoIP settings on reboot
Hi When we reboot these switches for updates or moving the VoIP are lost. Do the configs have to be saved on another page? I've had a look around, but I can't see any other options. Thanks. ...
rjp1977
Dec 29, 2021Aspirant
Hi DaneA
Thanks for that. It is at the latest version. I will try to reset it and see if that works. We have a few more that also seem to do the same thing as well.
Thanks.
Rich
rjp1977
Hi
I've done a bit more research and it appears to be the same issue as the one below that was never resolved.
Thanks.
Richard
