tomte
May 26, 2020Tutor
Switch reboots in endless loop when 2 ports are connected to 10G
Hi, hopefully someone here as a solution (the Singapore Netgear support refused any support since I bought the switch off Newegg). Switch operates normal with 6 ports used, but as soon as both 10G ...
- Jun 05, 2020
The new power supply (3A) seem to have solved the issue. Thanks for all the feedback.
