tantony's avatar
tantony
Luminary
Jun 24, 2019
Switch VoIP configuration
I posted a question about configuring switches for VoIP.  Please see below.  I followed the instructions on the NetGear PDF.   https://community.netgear.com/t5/Smart-Plus-Click-Switches/LLDP-for-Vo...
  • schumaku's avatar
    schumaku
    Jun 24, 2019
    There is no right or wrong.
    With VoIP phones (configured tagged for a specific VoiceVLAN) and a data passthrough (commonly untagged) it might be easier having  static config.
    You are free to try and test - it's a few clicks, so why bother? Or do some manager expect going live the same hour the same day? You need to build on your own experience, and should be free to run some testing, too.
ProSupport for Business
