tantony
Jun 24, 2019Luminary
Switch VoIP configuration
I posted a question about configuring switches for VoIP. Please see below. I followed the instructions on the NetGear PDF. https://community.netgear.com/t5/Smart-Plus-Click-Switches/LLDP-for-Vo...
- Jun 24, 2019
There is no right or wrong.
With VoIP phones (configured tagged for a specific VoiceVLAN) and a data passthrough (commonly untagged) it might be easier having static config.
You are free to try and test - it's a few clicks, so why bother? Or do some manager expect going live the same hour the same day? You need to build on your own experience, and should be free to run some testing, too.
schumaku
Jun 24, 2019Guru - Experienced User
tantony
The VoIP router is going to have the VLAN for the VoIP phones. This is my first time configuring VoIP so I just wanted to make sure. I followed your guide and other websites, and they're all showing to use Auto-VoIP, I just got concerned because the Netgear support told me something different. Ofcourse, I'll test, I was just seeking some suggestions.
My goal is to go live the same day, but no rush, users still have our old phones with us till I figure out VoIP. I didn't have time to test becaus the VoIP equimment won't be installed till tomorrow.
- tantonyJun 24, 2019Luminary
So just to make sure, I CAN use Auto-VoIP, if it works!
