tantony
Jun 24, 2019Luminary
Switch VoIP configuration
I posted a question about configuring switches for VoIP. Please see below. I followed the instructions on the NetGear PDF. https://community.netgear.com/t5/Smart-Plus-Click-Switches/LLDP-for-Vo...
- Jun 24, 2019
There is no right or wrong.
With VoIP phones (configured tagged for a specific VoiceVLAN) and a data passthrough (commonly untagged) it might be easier having static config.
You are free to try and test - it's a few clicks, so why bother? Or do some manager expect going live the same hour the same day? You need to build on your own experience, and should be free to run some testing, too.
tantony
Jun 25, 2019Luminary
The VoIP went well. I had to configure some switches with Auto-VoIP enabled and some with just hard coding the voice VLAN. Thank you for all the help!
schumaku
Jun 25, 2019Guru - Experienced User
Great, I like it that you have taken the plunge and build experience with both settings - good job!
