ijordison
Aug 07, 2020Aspirant
Switch WITHOUT 802.3az
I'm looking for a network switch which doesn't have 802.3az (Energy Eficient Ethernet) or where you can turn it off. Do the quoted models have the ability to turn it off? Or something with a similar form factor, where EEE can be turned off?
Welcome to the community! :)
There is no option to enable/disable EEE (Energy Efficient Ethernet) on the GS108E and GS308E switches.
I suggest you the GS108Tv3 or the GS110TPv3 switches instead. Both the GS108Tv3 and GS110TPv3 has an option to enable/disable EEE. As reference, kindly read pages 93-94 of the GS108Tv3/GS110TPv3 user manual here on how to enable/disable EEE.
To know about the specifications of both the GS108Tv3 and GS110TPv3, kindly check the data sheet here.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
DaneA
For what reason exactly?
- ijordisonAspirant
Dante.
It doesn't play nice with EEE.
