siletzspey's avatar
siletzspey
The handling of untagged packets across a physical network
I should be getting two GS308T units tomorrow.
Glancing at this forum and the owners manual, I feeling mystified about the handling of untagged packets, and the notion of packets "defaulting to VLAN1". In my case, I want to retain the flow of untagged packets across the physical network, in addition to adding two VLANs across the same physical network.
I have a Sonicwall TZ300, and easily configured three unique firewalled-zones/subnets, and binded them all to a single RJ-45 port with tagging/untagging as follows:
  1. Guest Subnet 192.168.0.0/24 - untagged packets
  2. Home Subnet 192.168.1.0/24 - V500 tagged packets
  3. Special Subnet 192.168.2.0/24 - V700 tagged packets
I also have a Ubuiquiti UAP-LR WAP, and easily configured it's single RJ-45 port with untagging/tagging as follows:
  1. untagged packets -> Guest SSID
  2. V500 tagged packets -> Home SSID
  3. V700 tagged packets -> Special SSID
I assume the TZ300 <-> Uniquiti CAT6 is properly called a "trunk", and that a proper trunk can have both tagged AND UNTAGGED packets?
With the GS308T tied into a second port off the SonicWall, WILL I BE ABLE TO HAVE:
  1. untagged packets -> GS308T RJ-45 ports 2-3
  2. V500 tagged packets -> GS308T RJ-45 ports 4-5
  3. V700 tagged packets -> GS308T RJ-45 ports 6-7
  4. the SonicWall will connect into GS308T port 1
The devices connected to GS308T ports 2-7 would be untagged, as the end devices are VLAN ignorant.
I'm mostly looking for early feedback of "yep it can be done", "might I suggest another approach" or "nope/LOL". I think my concern is the untagged packet handling.
For bonus points, if VLAN assingments are done by MAC addresses (instead of ports), and a GS308T port is tied to an ordinary unmanaged 8-port switch with 7 devices hanging off it, will the GS308T be ok with seeing 7 MACs on one port, and potentially having those MACs assigned to differing VLANs? (each MAC would only belong to one VLAN).
Thanks,
Thomas Gilg
  • schumaku's avatar
    schumaku
    Jan 06, 2021
    Thats the ah-haa I wanted to happen!
    On a switch, and by design you have one or multiple VLAN on a physical network.
    On the links, e.g. a Ethernet link, a LAG, ... a VLAN can be tagged (one or many), or untaged. A port where you want to connect a system for VLAN 123, is only an untagged member of VLAN 123, the PVID 123 does make untagged frames to enter the VLAN 123. The traffic in a VLAN is not VLAN "tagged" - while this is not fully correct,also QoS information can be part of a tag. How the frames are coming out of a port, with or without VLAN tags, is defined at the switch boundary. Where untagged frames are assigned to does also happen as defined by the PVID at the switch boundary.
    Similar for the wireless access point - there the VLAN is always* untagged on the SSID. (*Again, highly sophisticated designs allow one SSID and multiple VLANs, depending on the 802.1x authentication the VLAN membership can be assigned).
  • schumaku's avatar
    schumaku
    Hallo Thomas,
    Sure you can - both solutions are workable and can be implemented.
    Don't be confused about terms like trunk or access port. sure a trunk port can carry untagged and tagged frames, while an access port just carries untagged frames for a single VLAN. The trunk term is also used in the context of LAG/bonding/port trunking where multiple physical ports of the same speed and latency are combined into a trunk.
    By default, the ports on these switches are configured to the VLAN 1
    VLAN 1 [U]ntagged ... what makes the switch remove the tag from the frame when leaving the switch , and
    PVID 1 ... what makes incoming VLAN untagged frames to be associated to the VLAN 1.
    When creating a port connecting to the VLAN 500 resp. VLAN 700, ensure the PVID is also set to 500 resp. 700, and the port is removed from the default VLAN 1 by an [ ]empty entry.
    -Kurt
    • siletzspey's avatar
      siletzspey
      Thanks Kurt! Very helpful.
      Per your reply, an ah-ha seems to be... the "1" in "VLAN 1" does not imply packets vtagged with a 1. It seems the descriptor (token) "VLAN 1" could have been named "VLAN UNTAGGED" so as not to imply a vtag of 1.
      Edit/hum - do untagged packets OUTSIDE the switch get tagged with 1 for internal handling purposes within the switch? Outwardly I have untagged packets, but for brief periods within the switch they get mapped/unmapped from said "VLAN 1".
      My units should arrive today, and it will be fun to get hands on and pound it out.
      Thomas Gilg
      • schumaku's avatar
        schumaku
ProSupport for Business
