DavidHuen
Sep 08, 2026Aspirant
The SNMP service is occasionally unavailable
Hi all,
My customer is currently facing occasional SNMP unavailability. I have checked uptime ot the switch and found that CPU and memory are normal. After reset snmp, the snmp service resumed. However, after a period of time, this issue will occur again, and it is still unclear about the time interval and trggering conditions, which may be a software bug.
May I ask if anyone else has encountered the same problem and has a solution? Thank you.
Below information is the switch parameters:
[Product Name]
NETGEAR 48-Port Gigabit PoE+ Smart Managed Pro Switch with 4 SFP Ports (GS752TPv2)
[Model Name]
GS752TPv2
[Boot Version]
1.0.0.5
[Software Version]
6.0.3.3
It's not about the service becoming U/S - it does stop responing for reasons...
Netgear smart managed switches have built-in CPU protection mechanisms that can and do limit aggressive or recursive SNMP polling, which is sometimes flagged or dropped if mistaken for anomalous or resource-intensive traffic.
SNMP Polling Limitations & Security
- CPU Protection: Netgear switches restrict mass, recursive OID (Object Identifier) polling to prevent high CPU loads or lockups from monitoring tools.
- Rate Limiting: High-frequency polling intervals (such as querying every few seconds across hundreds of ports) can overwhelm the limited management CPU on Smart Managed switches.
- Mitigation: Increase polling intervals (e.g., to 60 seconds or more) and use targeted OIDs rather than bulk walk commands.
Intrusion Prevention and Management
Lack of Deep IPS: Netgear smart managed switches operate at Layer 2/3 and do not feature full inline Intrusion Prevention Systems (IPS) or deep packet inspection (DPI) like dedicated firewalls or UTM appliances.
Built-in Attack Mitigation: They offer basic security features such as DoS prevention, Access Control Lists (ACLs), and port security to drop malformed packets or limit unauthorized management access.
Interaction: Heavy SNMP polling combined with security features like DoS or storm control can occasionally cause the switch management interface to become unresponsive or drop ICMP/SNMP packets if CPU thresholds are crossed.
Intrusion Prevention & Security Triggers
While the switch does not feature active inline Intrusion Prevention (IPS), it utilizes specific built-in defensive configurations that can flag heavy SNMP traffic as a threat:- Denial of Service (DoS) Protection: If you have enabled global DoS protection in the management portal under Security > Management Security, the switch tracks high packet rates destined for its own IP address. Aggressive, multithreaded polling can easily look like a management-plane UDP flood or a brute-force sweep, causing the switch to drop the polling packets entirely.
- Auto-Protection Engine (Storm Control): If your monitoring server sits on a port where Broadcast/Multicast/Unknown Unicast Storm Control is strictly limited, high bursts of discovery packets can result in the switch rate-limiting or blocking the monitoring port altogether.
Have no such switch at hand, so please check
Management > Denial of Service > Auto-DOS Configuration
Security > Traffic Control
Better, more promising with less effort? Start here:
Optimize Your Network Management System (NMS)
If you prefer not to lower the switch’s security posture, you can adapt your monitoring software to respect the low-power microcontrollers inside Smart Managed units:
Increase Polling Intervals: Switch from 1-minute intervals to a minimum of 3 to 5 minutes.
Restrict OID Scope: Stop bulk-walking the entire MIB tree. Explicitly configure the pollers to only query essential OIDs (like specific port traffic statistics) to keep CPU overhead minimized. -
Implement a Polling Delay: Set a small delay (e.g., 20–50ms) between consecutive OID requests in your monitoring profile to prevent packet bursts.
- DavidHuenAspirant
Hi~Schumaku, thanks so much for your idea firstly. I furcher checked the customer's device and found the SNMP client was configured with 0.0.0.0 as a netmask, which means that any IP address can attempt to poll snmp data. I am currently recommending customer to add whitelist on their Routerto prevent unauthorized users from polling snmp data.
Thanks again for your idea.
