mschumacher777's avatar
Jan 18, 2026
Three GS308E, PFSense, cannot get VLAN working on third switch
I'm working on getting VLAN setup in my home network.  All of the switches are GS308E and have the VLAN turned on for the type "Advanced 802.1Q VLAN".
The "LAN" coming into Port 1 of Switch 1 is coming from the TPLink Switch that is connected to the PFSense box.  Switch 1 with Port 2 connects to Switch 2 with Port 1.  The same for Switch 2 Port 2 connects to Switch 3 with Port 1.  Eventually Switch 3 with Port 2 will connect to a ReoLink PoE for my Cameras/Frigate setup.
On Switch 1:
  • Ports 6, 7, and 8 setup for VLAN 400.
  • Ports 3 setup for VLAN 300.
  • Ports 2 setup to go to Port 1 of Switch 2
  • Ports 1 setup to connect to the LAN
On Switch 2:
  • Port 1 is connected to Switch 1 Port 2
  • Port 2 is connected to Switch 3 Port 1
  • No VLAN has been setup at this point on this Switch
On Switch 3:
  • Port 1 is connected to Switch 2 Port 2
  • Port 8 is setup for VLAN 602
For all the Switches I have the VLAN 1 which is the default VLAN.
For Switch 1, I'm able to connect my laptop with Ubuntu 24.04 and a Raspberry Pi 5 with Ubuntu 24.04 just fine to Port 6-8.
I've tried to connect another computer (Ubuntu 24.04) to Switch 3 Port 8, but it fails to connect.  I've taken my laptop and tried, but it also doesn't connect.  Now when I connect to like Switch 3 port 6, it connects just fine.
I started this post last night, but just finishing it up this morning.  I'll dig back into the setup of things and see if I have done something incorrectly.
Below is the setup of PFSense and an outline of how I have configured the Switches.  If there is something else that I'm not included, please ask for it and I'll see if I can capture it, as I'll be messing around trying to get this to work.
I've put in screen shots of the PFSense setup - put in bold of my comments so they stand out...
PICS will be done during edits of this post - won't post to start...
In Pfsense I can see my three switches (which have not been assigned a static IP at this point)
In Pfsense, these are the VLAN setup.
These are the Interface Assignments:
Here is the Configuration of the SecurityCams2 (VLAN 602)
The configuration of the DHCP Servier for VLAN 602
The last part, the Rules for the new VLAN.
Switch Configurations
Ports-Connections and VLAN assignment
Switch 1
Port 1 - Connects to the LAN of the PFSense Box
Port 2 - Connects to the Port 1 of Switch TWO
Port 6 - VLAN 400
Port 7 - VLAN 400
Port 8 - VLAN 400
Switch 2
Port 1- Connects to LAN of the PFSense box going to Switch 1 port TWO
Port 2- Connects to the Port 1 of Switch THREE
Switch 3
Port 1 - Connects to LAN of the PFSense box going to Switch 2 port TWO
Port 2 - Will connect to another switch, but have not connected at this point.
Port8 - VLAN 602
VLANs Definition in Switch 1
VLAN=1 (Default)
Port 1 - U
Port 2 -U
Port 3 - E
Port 4- U
Port 5- U
Port 6- E
Port 7- E
Port 8- E
VLAN=300
Port 1 - T
Port 2 -T
Port 3 - U
Port 4- E
Port 5- E
Port 6- E
Port 7- E
Port 8- E
VLAN=400
Port 1 - T
Port 2 -T
Port 3 - E
Port 4- E
Port 5- E
Port 6- U
Port 7- U
Port 8- U
VLANs Definition in Switch 2
VLAN=1 (Default)
Port 1 - U
Port 2 -U
Port 3 - U
Port 4- U
Port 5- U
Port 6- U
Port 7- U
Port 8- U
VLANs Definition in Switch 3
VLAN=1 (Default)
Port 1 - U
Port 2 -U
Port 3 - U
Port 4- U
Port 5- U
Port 6- U
Port 7- U
Port 8- E
VLAN=602
Port 1 - T
Port 2 -E
Port 3 - E
Port 4- E
Port 5- E
Port 6- E
Port 7- E
Port 8- U
PVID table
Switch 1
Port 1 - 1*, 300, 400
Port 2- 1*, 300, 400
Port 3- 300*
Port 4- 1*
Port 5- 1*
Port 6- 400*
Port 7 - 400*
Port 8 - 400*
Switch 2
Port 1 - 1*, 602
Port 2- 1*
Port 3- 1*
Port 4- 1*
Port 5- 1*
Port 6- 1*
Port 7 - 1*
Port 8 - 602*
Switch 3
Port 1 - 1*, 602
Port 2- 1*
Port 3- 1*
Port 4- 1*
Port 5- 1*
Port 6- 1*
Port 7 - 1*
Port 8 - 602*
  • I cannot get images included into the post - might be limit since this is my first post.
    Do I have to add the VLAN 602 to Switch 1 and 2?  If so, how can that be accomplished as when I tried once, it wanted me to assign a port for Switch 1.
    I'll mess around and see if I can get something accomplished.
    • StephenB's avatar
      Yes.  Otherwise that VLAN is fully isolated.
      Generally I think it's best to set up the all the switch<-> switch connections as "trunks" - carrying all VLANS, and tagged.
      I've never set up a pfsense firewall/router, but I suspect you will need to do the same thing on the switch<->pfsense interface.
      • schumaku's avatar
        schumaku
        Yes. But keep in mind these GS308E  don't come with a dedicated management VLAN. The simple IP stack on these switches can never be reached by tagged frames, only by untagged ones. So what makes up the management LAN must be strictly kept as an untagged network.
        While the OP talks of there GS308E, there are no (VLAN) config details of the forth TP Link switch. So somehow there are four switches on Our network.
        No idea why this wonderful SaaS platform seems no longer accepting (online) images - since ChristineT is no longer working with Netgear, I have no more contact to an active and responsive community admin...
ProSupport for Business
