FransVerhoeve
Nov 27, 2018Aspirant
throughput of 100mbit instead of 1000mbit.
I am using GS108PEv3 switch I connect a HikVision PoE IP camera to this. I use cabel type cab 6 S.FTP. The distance between camera and switch is 1 meter. I see that there is only a throughput of 100...
- Nov 27, 2018
You're more than welcome. Thanks!
FransVerhoeve
Sorry Schumaku, type: hikvision DS2CD2345FWDI 2,8
Best regards,
Frans
LaurentMa
Nov 27, 2018NETGEAR Expert
Hello,
schumaku was correct, this model has a Fast Ethernet (10/100M) port, as stated on page 3 of this spec sheet.
- FransVerhoeveNov 27, 2018Aspirant
Thank you very much for your quick response schumaku and LaurentMa!
I could have known. Sorry for this misunderstanding.
Best Regards
Frans
- LaurentMaNov 27, 2018NETGEAR Expert
