FransVerhoeve's avatar
Nov 27, 2018
throughput of 100mbit instead of 1000mbit.
I am using GS108PEv3 switch I connect a HikVision PoE IP camera to this. I use cabel type cab 6 S.FTP. The distance between camera and switch is 1 meter. I see that there is only a throughput of 100...
  • LaurentMa's avatar
    LaurentMa
    Nov 27, 2018
    You're more than welcome. Thanks!
ProSupport for Business
