HomeServerGuy's avatar
Dec 02, 2016
Time Configuration problems on a GS724Tv4
I am having problems getting the SNTP Time Configuration client to work. Its doesnt even look like its trying to get a time from any server I enter. Has anybody got any advice on how to make it work?...
  • DaneA's avatar
    DaneA
    May 09, 2019
    Here are the steps in troubleshooting Time Configuration on a NETGEAR Smart Switch:
    1. Make the firmware is on the latest version.
    2. On the SNTP Server Configuration Address, try to use an NTP pool specific to your country.  For example: if you are in Czech Republic, use cz.pool.ntp.org or the equivalent IP Address of the NTP pool.
    3. Check if you have a DNS configured on the switch.
    4. Try to set the IP Address of the default gateway on the SNTP Server Configuration Address.
    5. Factory reset the switch and start from scratch.
    6. If the same problem occurs after trying the steps above, kindly open a chat or online support ticket with NETGEAR Support at anytime.
    DaneA
    NETGEAR Community Team
ProSupport for Business
