11phc
Feb 17, 2018Aspirant
Total Packets Received with MAC Errors
Does anyone know what "Total Packets Received with MAC Errors" errors are? I am getting a load of these on a GS728TP coming in to a fiber interface, and I cant find any reference anywhere on the...
- Feb 20, 2018
Thanks very much, it is odd that phrase doesn't turn up anywhere in google if it's in your manual, but there we go.
Swapping out the patch cable seems to be what has fixed it anyway.
11phc
Feb 20, 2018Aspirant
DaneA
Feb 20, 2018NETGEAR Employee Retired
Thanks for the feedback. I'm glad to know that swapping out the patch cable seemed to fixed the problem. :)
Since your concern has been fixed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
