InternJoe's avatar
InternJoe
Follower
Apr 08, 2026
Total Power Budget 83W but total load maybe 100W at power-on
Hi all, we plan to use Netgear GS305EPP for a new project. This has 4 PoE ports with a maximum power budget of 83W.
All 4 PoE ports will be connected to a PoE device that can use up to 25.5W but average usage is only 10W or so.
So possible maximum at start-up or power-on is 102W with average total power usage of 40W.
Is our use case OK for GS305EPP?
  • schumaku's avatar
    schumaku
    Somehow you mixed up the specs of the unmanaged GS305PP (max 83W) with the GS305EPP (max 120W power budget).
    Either way, I'm with stuart012broad​ : If your project requires more than this - even in a small margin - the PoE controller might refuse powering the fourth powered device requesting 25.4 watts.
    Look for the GS308EPP instead. It won't kill your hardware budget - and you are on the safe and the supported side with your project.
    Probably yes. There is a max 120W power budget according to the GS305EPP data sheet.
    PS Sorry, I had a 100W power budget in my head when initially replying here.
  • The Netgear GS305EPP has an 83W PoE budget, while your worst-case startup draw (102W) exceeds that. Even if average use is only ~40W, at boot or peak load the switch may shut down ports, stagger power, or fail to power all devices.
ProSupport for Business
