Josh_Manton
Nov 05, 2023Guide
Two Active Switches With Redundant Uplink
Hi, I am looking to connect both switches to my Firewalla each on port one. I am also looking to create a LAG between the two switches on the sfp ports. I am using the default vlan to assign ip add...
schumaku
Nov 08, 2023Guru - Experienced User
Josh_Manton wrote:
I did not need to enable MSTP since each switch is 1 hop from the router.
Wild guess: These two router ports which are supposed to seamless connect both switches, providing a single STP environment, or for the allows to run two MSTP entities are mainly L3 router ports, without much L2 support - or the L2 STP/MSTP config on your router requires a review.
Josh_Manton wrote:
What I needed to do is under, Switching => STP, enable the option for "Forward BPDU while STP Disabled" and disable "Spanning Tree State". This allows the router to receive the packets that it is sending out and properly map out the network.
With al due respect, this reads like a hack, not a solution.
Josh_Manton
Nov 08, 2023Guide
No offense taken. It is possible that keeping STP on is fine, but not MSTP because the firewall (firewalla) only supports standard STP which is probably RSTP. It does not support MSTP. Since I don’t have an actual tree, more of a circle, I don’t think I need to enable STP on the switches. What do you think? The two firewall ports are each multi-honed, 2 subnets separated by vlans. Each subnet has STP enabled.
Does this still sound like a hack?
- schumakuNov 09, 2023Guru - Experienced User
Much easier would be to configure firewalla with multiple ports bridged into a single LAN, and connect these physical ports to one of the switches each.
For this purpose, STP must be enabled on the firewalla on these single LAN for the two bridged ports. This would not make redundancy, but allow two dedicated uplink ports connected to the firewall.
As you have just one active firewall, I'm a little bit lost on how you expect to configure a redundant network. Sure, you could make up a loop and interconnect the two switches direct, permitting you have at lest STP, better some more advanced RSTP to avoid these long recovery times - however, this firewall does not seem to support RSTP.
As STP failover does take 20..30 seconds or more, its not uncommon your network would be blocked fr about 25 seconds following an STP change. https://help.firewalla.com/hc/en-us/articles/14486004537235-Device-is-slow-to-get-an-IP-address-Spanning-Tree-Protocol-STP-
- Josh_MantonNov 09, 2023Guide
It turns out you were 100% correct, it was a hack.
Upon reading this post I made a few changes:
https://help.firewalla.com/hc/en-us/community/posts/360053051193-New-device-setup-Question-for-GOLD-
I decided I did not want to get into the complexity of a loop system, so I elected for a tree (more like a branch).
Firewalla (fw) => MS510TXM (s1) => MS510TXM (s2)
LAG from fw => s1
LAG from s1 => s2
I have MSTP enabled on s1 and s2
I let the switches auto populate Port Path Cost, and everything just worked.
Things i've learned (which I believe are correct):
1. If STP is not enabled, the up-stream switches wont learn the path to ports on the down-stream switches. I originally assumed that STP was only to block/configure loops.
2. Creating a loop network is more complicated. It is probably easier if my Firewall was Netgear. My first and only attempt to create a loop failed for two reasons: 1) I did not know what I was doing. 2) My connections from my Firewall to each of the 2 Switches was 2.5Gib while the connection between the two Switches was 10Gib. This is non-standard in the enterprise world and I've learned that STP takes into account the connection speed when calculating the Cost, so it was miscalculating the Root.
Thank you for calling my first solution a hack. It just motivated me to dig deeper.
I have one unrelated question for you.
I was using the web interface on the switches for a week without issue. Then I needed to reload the exported configuration on both. Now when I click on some of the menu items the content fails to load, but not all the time. I see in the browser log that there are CORS errors. I switched over to https and that resolved the issue but the interface is now lagging a little. I have tried to remove the cookies and delete any browser cache.
I am using DHCP reservation to assign IP addresses and I access the switches using hostnames configured on the internal dns server. This issue does not happen if I use IP address.
