TomasRozek
Jan 06, 2021Aspirant
Two switches GS748Tv5 connecting to each other - different rooms
Hello, I would like to ask you for help. I am not too deep in networking and I need connect two switches to each other. I don´t expect any funcionality, just normal switching and when I connected tw...
schumaku
Jan 06, 2021Guru - Experienced User
Whatever the link between the two switches is made of (wall installation with plugs, two patch cables?) - this reads like the wiring is incomplete or not correct installed to pairs.
- TomasRozekJan 06, 2021Aspirant
Hello,
Well, there was another switch before and it was working perfectly fine. It was some old edgeCore. It was old and gigabit. Connection between these two racks are via normal cabelling, not patchcord but wall installation (CAT6e). I can measure it it there are some errors in quality of cables, but because it was working properly, I have expected some setup on switch.
Thank you
Tomas
