fromnaija's avatar
fromnaija
Unable to connect to gs716tv3 switch
I am not able to connect to the switch through the web GUI. I downloaded and installed Smart Control Center as well asProsafe Plus Utility. These did not work as well. I have reset to factory default...
  • fromnaija's avatar
    fromnaija
    Dec 22, 2016
    After banging my heads for several hours, I found out I was pressing the reset button and not the factory reset button. I didn't know there were two different holes you could poke and I was working in a dark room.
    Everything worked as designed after a proper factory reset. Thank you!
ProSupport for Business
