mikey6283
Jan 17, 2024Aspirant
Unable to sign into GS308E
I have struggled to find answer how to sign into GS308E. as i think that the switch is faulty. according to my product information the hardware warranty is till 2025. How do i contact Netgear suppor...
Jan 17, 2024Guru - Experienced User
I've seen issues when using this at home (or work) environments when the default IP address range is 192.168.1.*** or 10.0.0.***. there's ways around that but an easy one for many users is just to change your routers range to the 192.168.0.*** range. Then when the router reboots with the switch connected, you can connect to its default address.
for the fancier methods, schumaku is the expert. Mines is just the cheater/easy trick that I've used before.
What I've done if the routers sub net differs from the default IP on the switch, configure one wired PC or laptop for a static IP of 192.168.0.something. Use same subnet as default switches. No gateway or DNS needed. Don't connect the switch to anything. Then connect the PC to the Switch then you should be able to get to the switches web page using it's default IP address after the factory reset. Should see switches log in page here. If you do, log in and change the switches networking settings to match your main routers subnet networking. Static IP and something addressed outside of the routers default IP address pool range. I have two NG GS108Ts configured this way.
