damaje210's avatar
damaje210
Update firmware on GS748TS
I have 4 GS748TS switches stacked and have never updated firmware. The current boot version is 1.0.1.5 and software version is v5.0.0.23. 1st please let me know if this switch is end of life. If not...
  • DanielZhang's avatar
    Jul 24, 2017
    Hi Damaje210,
    Welcome to NETGEAR community!:smileyhappy:
    Unfortunately that the GS748TS is EOL(End of life) now.
    Now we have new powerful and ease of use stackable switch S3300 series.
    We suggest you to upgrade to our new smart stackable switch S3300 series.:smileyhappy:
    Otherwise, you can also upgrade your GS748TS to new firmware that is 5.2.0.11 if you want to try.
    But the upgrade process need very careful operate.(separate stack member/backup configuration file/restore stack unit ID)
    You can get the upgrade instruction from following link:
    How to upgrade GS748TS to 5.2.0.11
    I don't suggest you to upgrade firmware on your current stack if no any block issue appeared.
    May the solution help you.:smileyhappy:
ProSupport for Business
