gdlgiii
Dec 31, 2017Tutor
Update home network for IoT and private devices
Using a Netgear R8000 Nighthawk router, I would like to connect 2 GS108Tv2 switches to support 2 VLANs. I want to separate the computers, phones, tablets from the Arlo Cameras, Google Home, Chromecas...
- Jan 01, 2018You should set the default VLAN for an untagged port to the VLAN that you want untagged traffic received on that port to be mapped to. So that means the default VLAN for the ports connected to the HTPC, PC, NAS and RPi3 should be set to the private VLAN. And the ports for your IoT devices should have their default VLAN set to the IoT VLAN.
gdlgiii
Dec 31, 2017Tutor
So, if I obtain an Ubiquiti EdgeRouter Lite, I could possibly do this? Thinking of devices that are not VLAN aware, perhaps it would be best to set the default vlan to the new IoT (vlan50) vlan on untagged ports?
I sent an different layout. I don't think I will have funds to purchase the netgear AP and will need to repurpose netgear routers.I have 1 R8000 and 2 R7000 routers I could use as APs for their respected vlan I would think.
TheEther
Dec 31, 2017Guru
Yes, an Edgerouter Lite would work. I have one and it's great.
What are you trying to accomplish with this?
Looks like your new layout just has the R8000 swapped out with an Edgerouter, but it still shows the WAC730. Anyway, you can certainly use the R8000 and R7000 as APs and place each one in a different VLAN.
- gdlgiiiDec 31, 2017Tutor
I forgot to remove the WAC730 AP from the diagram. My goal for this is to separate private network traffic from IoT traffic while repurposing some existing hardware. I am trying to keep it somewhat simple while keeping a secure environment.
- TheEtherDec 31, 2017GuruI understand, but I don't know what's your rationale about setting untagged ports to default to the IoT VLAN?
- gdlgiiiJan 01, 2018TutorMy thinking (if I'm correct) was to use the untagged ports to connect the Arlo camera base stations to since they do not support vlans.
Keeping the IoT vlan as default vlan for untagged ports would work best I believe to keep that traffic separate from the private network.
