mnahum
Dec 16, 2020Aspirant
updating firmware on GS110TP V2 from
I never had to update my GS110 TP v2 until now where I had a major issue and had to reboot it. the current version is: Model Name | Boot Version | Software Version GS110TP | B5.1.0.2 | 5.4.2.18...
schumaku
Dec 17, 2020Guru - Experienced User
Double check you have the ZIP archive extracted and use the STK file for the upload. (Sigh - and don't be confused this ol Web UI does talk of Download...).
If you have a Windows 10 system at hand, try Internet Explorer (IE10).
Have not spotted any requirements for uaing some intermediate firmware builds - you can check it yourself from https://www.netgear.com/support/product/GS110TP.aspx#download - there is a "+ View previous versions" to the end of the current downloads.
Here are the Release Notes and the how-to: GS110TP / GS108Tv2 Firmware Version 5.4.2.33
- mcnahumDec 17, 2020Apprentice
by reading the released note I got that Java was needed ... I setup a win10 VM with Java... and it worked...
- schumakuDec 17, 2020Guru - Experienced User
Java is (or more was) just required for the Device View. For the Web UI and the firmware update it's not required. However, have used IE for the update from the new virtual Win10?
